Ana içeriğe geç
InFocus LP540 Projector Lamp Replacement
Neye ihtiyacın var
  1. InFocus LP540 Projector Lamp Replacement, Lamp: adım 1, 2 resimden 1. InFocus LP540 Projector Lamp Replacement, Lamp: adım 1, 2 resimden 2.
    • Place the projector on its back with the control buttons facing down.
    • Remove the black 7mm screw on the external case with a Phillips 2 screwdriver.
  2. InFocus LP540 Projector Lamp Replacement: adım 2, 1 resimden 1.
    • Use the plastic flat-head to remove the lamp lid.
  3. InFocus LP540 Projector Lamp Replacement: adım 3, 2 resimden 1. InFocus LP540 Projector Lamp Replacement: adım 3, 2 resimden 2.
    • Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head.
    • Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
  4. InFocus LP540 Projector Lamp Replacement: adım 4, 3 resimden 1. InFocus LP540 Projector Lamp Replacement: adım 4, 3 resimden 2. InFocus LP540 Projector Lamp Replacement: adım 4, 3 resimden 3.
    • Grab the silver handle.
    • Unhook the handle so it can move freely.
    • Pull the handle straight up until the lamp is completely removed from projector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jorge L Navarro
533 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-17, Regan Winter 2014 Cal Poly, Team 13-17, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G17
6 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 49
Her zaman: 3,395
