Ana içeriğe geç
InFocus LP540 Projector Main Fans Replacement
Neye ihtiyacın var
  1. InFocus LP540 Projector Main Fans Replacement, Main Board: adım 1, 3 resimden 1. InFocus LP540 Projector Main Fans Replacement, Main Board: adım 1, 3 resimden 2. InFocus LP540 Projector Main Fans Replacement, Main Board: adım 1, 3 resimden 3.
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7 mm metallic screws using the flat-head screwdriver.
    • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
  2. InFocus LP540 Projector Main Fans Replacement: adım 2, 2 resimden 1. InFocus LP540 Projector Main Fans Replacement: adım 2, 2 resimden 2.
    • Flip the projector over.
    • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
  3. InFocus LP540 Projector Main Fans Replacement: adım 3, 3 resimden 1. InFocus LP540 Projector Main Fans Replacement: adım 3, 3 resimden 2. InFocus LP540 Projector Main Fans Replacement: adım 3, 3 resimden 3.
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Remove the top cover.
  4. InFocus LP540 Projector Main Fans Replacement: adım 4, 2 resimden 1. InFocus LP540 Projector Main Fans Replacement: adım 4, 2 resimden 2.
    • Hold down the release tabs to remove the cables from the white tabs.
  5. InFocus LP540 Projector Main Fans Replacement: adım 5, 3 resimden 1. InFocus LP540 Projector Main Fans Replacement: adım 5, 3 resimden 2. InFocus LP540 Projector Main Fans Replacement: adım 5, 3 resimden 3.
    • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
    • Pull up the five metal tabs located at the rear of the projector.
    • Do not pull up on the metal tabs too hard or too fast because they can break easily.
  6. InFocus LP540 Projector Main Fans Replacement: adım 6, 3 resimden 1. InFocus LP540 Projector Main Fans Replacement: adım 6, 3 resimden 2. InFocus LP540 Projector Main Fans Replacement: adım 6, 3 resimden 3.
    • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
    • Pull the ribbons out carefully and place them under the main board.
    • Carefully lift the entire main board up.
  7. InFocus LP540 Projector Main Fans Replacement, Main Fans: adım 7, 2 resimden 1. InFocus LP540 Projector Main Fans Replacement, Main Fans: adım 7, 2 resimden 2.
    • Once the main board has been removed, carefully lift the fans upward. Make sure no cables are tangled in the process.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jorge L Navarro
533 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-17, Regan Winter 2014 Cal Poly, Team 13-17, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G17
6 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 64
Her zaman: 1,665
