Giriş
Replace the lens if you are experiencing a lack of an image when the projector is on.
You will need a replacement lens as well as a clean, micro fabric cloth in case the replacement lens needs to be cleaned.
Neye ihtiyacın var
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
Gently pull out the lens.
To reassemble the device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
