Ana içeriğe geç
InFocus Screenplay 4805 Motherboard Replacement
Neye ihtiyacın var
    1. InFocus Screenplay 4805 Motherboard Replacement, Top Panel: adım 1, 3 resimden 1. InFocus Screenplay 4805 Motherboard Replacement, Top Panel: adım 1, 3 resimden 2. InFocus Screenplay 4805 Motherboard Replacement, Top Panel: adım 1, 3 resimden 3.
      • Flip the projector on its back.
      • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
      • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
      FixBot'a Sor
      Yorum Ekle
    2. InFocus Screenplay 4805 Motherboard Replacement: adım 2, 2 resimden 1. InFocus Screenplay 4805 Motherboard Replacement: adım 2, 2 resimden 2.
      • Turn the projector, facing the back cable board towards you.
      • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
      • Gently take off back cable panel.
      FixBot'a Sor
      Yorum Ekle
    3. InFocus Screenplay 4805 Motherboard Replacement: adım 3, 3 resimden 1. InFocus Screenplay 4805 Motherboard Replacement: adım 3, 3 resimden 2. InFocus Screenplay 4805 Motherboard Replacement: adım 3, 3 resimden 3.
      • Turn the projector so the front side with the lens is facing you.
      • Gently pry the both of the grey lens rings using the metal spudger.
      FixBot'a Sor
      Yorum Ekle
    4. InFocus Screenplay 4805 Motherboard Replacement: adım 4, 1 resimden 1.
      • Now that the screws have been removed, proceed with the removal of the outer panel.
      • Gently remove the front lens panel.
      • Be forewarned, the panel will resist. Be careful not to break the lens.
      FixBot'a Sor
      Yorum Ekle
    5. InFocus Screenplay 4805 Motherboard Replacement: adım 5, 1 resimden 1.
      • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
      • Rest the lid behind the projector so the insides are exposed and undamaged.
      FixBot'a Sor
      Yorum Ekle
    1. InFocus Screenplay 4805 Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. InFocus Screenplay 4805 Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. InFocus Screenplay 4805 Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
      • Using the Phillips #1 screwdriver, remove the (4) four 1.5 cm screws on each of the four corners of the motherboard cover.
      • Remove the white tab connected to the light bulb.
      FixBot'a Sor
      Yorum Ekle
    2. InFocus Screenplay 4805 Motherboard Replacement: adım 7, 3 resimden 1. InFocus Screenplay 4805 Motherboard Replacement: adım 7, 3 resimden 2. InFocus Screenplay 4805 Motherboard Replacement: adım 7, 3 resimden 3.
      • Gently pull the white tab on the right side of the silver power housing by pinching each side of it.
      • Pinch the two black tabs on the inside of the cover to remove.
      • Gently pull on the long white tab to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 687
