Ana içeriğe geç
InFocus X2 Lamp Replacement
Neye ihtiyacın var
  1. InFocus X2 Lamp Replacement, Open the Lamp Door: adım 1, 3 resimden 1. InFocus X2 Lamp Replacement, Open the Lamp Door: adım 1, 3 resimden 2. InFocus X2 Lamp Replacement, Open the Lamp Door: adım 1, 3 resimden 3.
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
    FixBot'a Sor
    Yorum Ekle
  2. InFocus X2 Lamp Replacement, Disconnect the Lamp: adım 2, 3 resimden 1. InFocus X2 Lamp Replacement, Disconnect the Lamp: adım 2, 3 resimden 2. InFocus X2 Lamp Replacement, Disconnect the Lamp: adım 2, 3 resimden 3.
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
    FixBot'a Sor
    Yorum Ekle
  3. InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: adım 3, 3 resimden 1. InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: adım 3, 3 resimden 2. InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: adım 3, 3 resimden 3.
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
    FixBot'a Sor
    Yorum Ekle
  4. InFocus X2 Lamp Replacement, Remove the Old Lamp: adım 4, 1 resimden 1.
    • Pull on the bottom plastic tab and remove the lamp by hand.
    FixBot'a Sor
    Yorum Ekle
  5. InFocus X2 Lamp Replacement, Insert the New Lamp: adım 5, 1 resimden 1.
    • Insert the replacement lamp into the projector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Caution: The old bulb contains mercury. Please recycle it in a safe and appropriate manner. Look for your local recycling information at https://earth911.com/
Ekli Belgeler
Paulina Duarte
553 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S1G3
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 1,150
