Ana içeriğe geç
Giriş
Prereq only.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
  1. Place a coupling over the pump rod, on top of the rod vise. Place a coupling over the pump rod, on top of the rod vise.
    • Place a coupling over the pump rod, on top of the rod vise.
  2. Reattach the T-handle to the top of the pump rod. Reattach the T-handle to the top of the pump rod. Reattach the T-handle to the top of the pump rod.
    • Reattach the T-handle to the top of the pump rod.
  3. Loosen and remove the rod vise from the pump rod. The coupling will drop down onto the riser main. The coupling will drop down onto the riser main.
    • Loosen and remove the rod vise from the pump rod.
    • The coupling will drop down onto the riser main.
  4. Screw the coupling onto the end of the riser main. Use a pipe wrench to tighten the coupling onto the riser main.
    • Screw the coupling onto the end of the riser main.
    • Use a pipe wrench to tighten the coupling onto the riser main.
Sonuç
Andrew Optimus Goldheart
483.559 İtibar
410 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
145 Üyeler
17.078 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 17
