Ana içeriğe geç
Giriş
The disassembling of the monitor is so to be able to change the screen or replace other components of the monitor.
Parçalar
Hiçbir parça belirtilmedi.
  1. Start by gently inserting the plastic opening tool between the led and casing.
    • Start by gently inserting the plastic opening tool between the led and casing.
  2. Slowly pry the cover away from the bottom using the plastic opening tool.
    • Slowly pry the cover away from the bottom using the plastic opening tool.
  3. Android Tamir Setleri
    A new screen or battery is one kit away.
    Hemen Alışveriş Yapın
  4. Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
    • Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
    This photo is a little blurry
    Patty Remmell - Yanıt
  5. Remove the cover and set it aside.
    • Remove the cover and set it aside.
  6. Remove the four corner screws, 5.0 mm, using a J1 bit. Lift the top away from the bottom using the metal spudger. Be careful not to rip the antenna wire.
    • Remove the four corner screws, 5.0 mm, using a J1 bit.
    • Lift the top away from the bottom using the metal spudger. Be careful not to rip the antenna wire.
    Lift it how? With a tool? With fingers?
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Larsha Johnson
478 İtibar
3 adet Kılavuz yazıldı
Takım
USF Tampa, Team 6-4, Remmell Fall 2015 USF Tampa, Team 6-4, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S6G4
4 Üyeler
2 Yorum
What is the part number for the LCD?
jstarion - Yanıt
From the pictures LQ035NC111 seem to be the part number.
Michael C -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 5,819
