Ana içeriğe geç
Infant Optics DXR-8 Monitor Screen Replacement
Neye ihtiyacın var
    1. Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: adım 1, 3 resimden 1. Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: adım 1, 3 resimden 2. Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: adım 1, 3 resimden 3.
      • Using the plastic opening tool, remove screen protector from front of monitor.
      FixBot'a Sor
      Yorum Ekle
    2. Infant Optics DXR-8 Monitor Screen Replacement: adım 2, 3 resimden 1. Infant Optics DXR-8 Monitor Screen Replacement: adım 2, 3 resimden 2. Infant Optics DXR-8 Monitor Screen Replacement: adım 2, 3 resimden 3.
      • Remove the six 4mm screws using a Phillips #00 screwdriver.
      • Remove the screen, exposing the circuit board.
      • Turn device over to expose rear circuit board.
      FixBot'a Sor
      Yorum Ekle
    3. Infant Optics DXR-8 Monitor Screen Replacement: adım 3, 3 resimden 1. Infant Optics DXR-8 Monitor Screen Replacement: adım 3, 3 resimden 2. Infant Optics DXR-8 Monitor Screen Replacement: adım 3, 3 resimden 3.
      • Disconnect speaker from monitor for ease of access by unplugging wire.
      FixBot'a Sor
      Yorum Ekle
    1. Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: adım 4, 3 resimden 1. Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: adım 4, 3 resimden 2. Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: adım 4, 3 resimden 3.
      • Using a plastic opening tool, disconnect the ribbon cable connector.
      • Gently separate the ribbon cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Infant Optics DXR-8 Monitor Screen Replacement: adım 5, 2 resimden 1. Infant Optics DXR-8 Monitor Screen Replacement: adım 5, 2 resimden 2.
      • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
      • Flip the motherboard away from the front case to reveal the screen on the other side.
      FixBot'a Sor
      Yorum Ekle
    3. Infant Optics DXR-8 Monitor Screen Replacement: adım 6, 1 resimden 1.
      • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
      FixBot'a Sor
      Yorum Ekle
    4. Infant Optics DXR-8 Monitor Screen Replacement: adım 7, 3 resimden 1. Infant Optics DXR-8 Monitor Screen Replacement: adım 7, 3 resimden 2. Infant Optics DXR-8 Monitor Screen Replacement: adım 7, 3 resimden 3.
      • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
      • Lift the screen off of the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
Hey Daniel!
Thanks for sharing ??
Where did you get the replacement part?
Ro Brandi - Yanıt Paylaş
On Amazon is the quickest option.
Hilitand LQ035NC111 LCD Display, 3.5inch TFT RGB LCD Display Module 320 x 240 Display Panel LQ035NC111 54pin LCD
Stebe - Yanıt Paylaş
Just completed the screen change, it works great! Thanks so much for this step by step guide.
The screen I ordered came with the metal brackets. Since the base was glued to the motherboard, it took a few extra steps of de-casing the one I got and re-casing onto the board. But worked fine.
I ordered: https://www.amazon.com/dp/B07NYN5PK2?psc...
James Quinlan - Yanıt Paylaş
Does this improve the brightness of the screen or is it essentially an OEM replacement? I have found the monitor to be basically unusable in daylight conditions (like every midday nap) so I’m hoping to add some anti glare and boost the screen brightness/contrast.
Thanks for the information!
Owen - Yanıt Paylaş
Excellent guide! Followed the step by step here and it went super smooth, new screen installed with no issues whatsoever!!
Thanks Daniel for putting it up and other authors for tweaking!
I hadn’t seen this website yet, but I’m glad I found it now!! This is awesome!!
Alan Bueno - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 60
Her zaman: 6,599
