Ana içeriğe geç
Infinity v2 10.1 Camera Replacement
Neye ihtiyacın var
  1. Infinity v2 10.1 Camera Replacement, Back Case: adım 1, 3 resimden 1. Infinity v2 10.1 Camera Replacement, Back Case: adım 1, 3 resimden 2. Infinity v2 10.1 Camera Replacement, Back Case: adım 1, 3 resimden 3.
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Camera Replacement: adım 2, 2 resimden 1. Infinity v2 10.1 Camera Replacement: adım 2, 2 resimden 2.
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Camera Replacement, Camera: adım 3, 1 resimden 1.
    • Use your thumb or opening tool to lift the black connector holding in the ribbon cable.
  4. Infinity v2 10.1 Camera Replacement: adım 4, 1 resimden 1.
    • Remove the camera by gently picking it up and pulling it free from the connector.
    • Avoid touching the lens of either camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
sammytarbokas
193 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 UMass Dartmouth, Team S2-G4, Barthe Fall 2019 üyesi
UMASSD-BARTHE-F19S2G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 108
