Parçalar
Hiçbir parçaya gerek yok.
  1. Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • To ensure you don't lose any tiny parts during the replacement process, place parts on the white magnetic sheet.
    • Once the screws have been removed, proceed to take off back cover.
  2. Now, proceed to lift the battery out and remove it.
    • Now, proceed to lift the battery out and remove it.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
    • Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
  5. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
    • Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
  6. Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary. Pull the motherboard out and down away from the top of the phone.
    • Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary.
    • Pull the motherboard out and down away from the top of the phone.
Sonuç
Lauren
43 İtibar
2 adet Kılavuz yazıldı
Takım
Ohio State, Team 1-4, Buehl Spring 2014 Ohio State, Team 1-4, Buehl Spring 2014 üyesi
OSU-BUEHL-S14S1G4
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 6
Her zaman: 428
