Giriş
This guide will take you through the process of replacing a broken or unusable screen on the Insignia 24" LED Roku TV.
Neye ihtiyacın var
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
Remove the base from the frame.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
Remove all the pieces of tape to detach the wires from both sides.
You want to gently peel the tape off, without pulling on the wires.
Now pull apart and separate the screen.
To reassemble your TV, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
