Ana içeriğe geç
Insignia 6-Quart Pressure Cooker Circuit Board Replacement
Neye ihtiyacın var
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: adım 1, 1 resimden 1.
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 2, 1 resimden 1.
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 3, 1 resimden 1.
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 4, 1 resimden 1.
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 5, 1 resimden 1.
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 6, 1 resimden 1.
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 7, 1 resimden 1.
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 8, 1 resimden 1.
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 9, 1 resimden 1.
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 10, 1 resimden 1.
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 11, 1 resimden 1.
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 12, 1 resimden 1.
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 13, 1 resimden 1.
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: adım 14, 1 resimden 1.
    • Remove and replace the circuit board.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Savannah Webb
657 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G3, Banghart Winter 2018 Cal Poly, Team S12-G3, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S12G3
4 Üyeler
8 Yorum
Where do you purchase the circuit board
Douglas Koons - Yanıt
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - Yanıt
Please, Where can I buy the electrical circuit?
Mohammed - Yanıt
why is my circuit board not fixed to the top like in the diagram
david stanley - Yanıt
where can I purchase the circuit board
de27@bellsouth.net - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 3,161
