Ana içeriğe geç
Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: adım 1, 1 resimden 1.
    • Remove the lid and place it upside-down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: adım 2, 1 resimden 1.
    • Pinch the rubber gasket on the float valve and pull up.
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: adım 3, 2 resimden 1. Insignia 6-Quart Pressure Cooker Float Valve Replacement: adım 3, 2 resimden 2.
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Savannah Webb
657 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S12-G3, Banghart Winter 2018 Cal Poly, Team S12-G3, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S12G3
4 Üyeler
2 Yorum
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - Yanıt
OK after much digging, I found the old valve and now it is pressurizing.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 76
Her zaman: 4,344
