Ana içeriğe geç
Insignia Flex 10.1 NS-P10A7100 Battery Replacement
Neye ihtiyacın var
  1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: adım 1, 3 resimden 1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: adım 1, 3 resimden 2. Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Use the blue iFixit opening tool to remove the backing of the device.
    • Wedge the tool in the crease between the device backing and screen.
  2. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: adım 2, 2 resimden 1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: adım 2, 2 resimden 2.
    • Disconnect the larger ribbon that runs along the top of the battery and connects to the motherboard.
    • Lift up the connector by pulling it up with your fingernail. The ribbon will then be released and you can detach it.
  3. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: adım 3, 2 resimden 1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: adım 3, 2 resimden 2.
    • Detach the five colored wires that connect the battery to the motherboard.
    • Use two fingers and place one on either side of the white plastic encasing the wires.
    • Pull on this piece to release it from the motherboard.
    • Now the battery is detached from the motherboard.
  4. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: adım 4, 3 resimden 1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: adım 4, 3 resimden 2. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: adım 4, 3 resimden 3.
    • The battery is now only connected to the device by the glue on the bottom.
    • Use the iFixit opening tool to wedge the battery off of the device. You will have to use some force to pry the battery off of the device.
    • Now that your battery is removed it is ready for replacement.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 972
