Ana içeriğe geç
Insignia Flex 10.1 NS-P10W8100 Keyboard Connector Replacement
Neye ihtiyacın var
  1. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement, Keyboard Connector: adım 1, 2 resimden 1. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement, Keyboard Connector: adım 1, 2 resimden 2.
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 2, 2 resimden 1. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 2, 2 resimden 2.
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to each side to help pry the back cover evenly.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 3, 1 resimden 1.
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off work your fingers around the corners and slowly pry the cover off.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 4, 2 resimden 1. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 4, 2 resimden 2.
    • Use your fingers to remove the tape holding down the zero insertion force (ZIF) connector ribbon attached to the keyboard.
    • Use your fingernails to flip the small locking flap. Then, you can safely pull the cable out.
  5. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 5, 1 resimden 1.
    • Pull back the yellow tape holding down the keyboard connector.
  6. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 6, 1 resimden 1.
    • Remove the two 4 mm screws using a Phillips #2 screwdriver.
  7. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 7, 2 resimden 1. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: adım 7, 2 resimden 2.
    • Remove the connector by lifting it upward.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 930
