Ana içeriğe geç
Insignia Flex 10.1 NS-P16AT10 Camera Replacement
Neye ihtiyacın var
  1. Insignia Flex 10.1 NS-P16AT10 Camera Replacement, Camera: adım 1, 2 resimden 1. Insignia Flex 10.1 NS-P16AT10 Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Make sure your device is off and not connected to any power sources to avoid injury
    • Use a plastic opening tool to remove the rear panel from the front case.
    • Insert the plastic opening tool between the front case and rear panel. Use a prying motion to lift the front case from the rear panel.
    • The volume rocker and power button will become free from the device when the front and rear panels are separated from each other. Do not worry. These pieces are easily put back into place when reassembling the tablet.
  2. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: adım 2, 2 resimden 1. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to flip up the ribbon connector that connects the camera to the motherboard.
    • Free the ribbon cable from the motherboard.
  3. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: adım 3, 2 resimden 1. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: adım 3, 2 resimden 2.
    • Use a #00 Phillips head screw driver to remove the two screws that hold the camera down to the front case.
  4. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers or your fingers to remove the camera from your Insignia Flex 10.1 NS-P16AT10.
  5. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: adım 5, 2 resimden 1. Insignia Flex 10.1 NS-P16AT10 Camera Replacement: adım 5, 2 resimden 2.
    • The camera is now free and ready to be replaced.
Sonuç
Morgan Kidd
419 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 12-3, Bennett Fall 2016 Texas Tech, Team 12-3, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S12G3
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 147
