Ana içeriğe geç
Insignia Flex 7 Battery Replacement
Neye ihtiyacın var
  1. Insignia Flex 7 Battery Replacement, Battery: adım 1, 3 resimden 1. Insignia Flex 7 Battery Replacement, Battery: adım 1, 3 resimden 2. Insignia Flex 7 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Battery Replacement: adım 2, 2 resimden 1. Insignia Flex 7 Battery Replacement: adım 2, 2 resimden 2.
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Battery Replacement: adım 3, 3 resimden 1. Insignia Flex 7 Battery Replacement: adım 3, 3 resimden 2. Insignia Flex 7 Battery Replacement: adım 3, 3 resimden 3.
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Link for replacement battery?
Mike - Yanıt
I'm also looking for a replacement battery and i've only found batteries with two cables instead of the 5 this one has
Jose Garza Lozano - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 940
