Giriş
A speaker may seem amazing at first but eventually, you'll notice something wrong. Either it stops working or you start hearing static. One of the best ways to solve this problem is to replace it. Doing so will require soldering. Therefore, be sure to follow safety rules during this process..
Neye ihtiyacın var
Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
Using a Phillips #000 screwdriver, remove the two 3.0mm long screws shown in the illustration.
Bir başkası bu kılavuzu tamamladı.
