Ana içeriğe geç
Insignia Flex 7 Speaker Replacement
Neye ihtiyacın var
  1. Insignia Flex 7 Speaker Replacement, Battery: adım 1, 3 resimden 1. Insignia Flex 7 Speaker Replacement, Battery: adım 1, 3 resimden 2. Insignia Flex 7 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Speaker Replacement: adım 2, 2 resimden 1. Insignia Flex 7 Speaker Replacement: adım 2, 2 resimden 2.
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Speaker Replacement: adım 3, 3 resimden 1. Insignia Flex 7 Speaker Replacement: adım 3, 3 resimden 2. Insignia Flex 7 Speaker Replacement: adım 3, 3 resimden 3.
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
  4. Insignia Flex 7 Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the two 3.0mm long screws shown in the illustration.
  5. Insignia Flex 7 Speaker Replacement: adım 5, 1 resimden 1.
    • Using the spudger, gently pry the speaker from it’s plastic socket.
  6. Insignia Flex 7 Speaker Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Apply heat to the solder junction of the red wire with a solder iron.
    • Once the solder melts, the wire can be disconnected from the circuit board. To do so, use tweezers to apply a gentle tension to the wire when the solder appears fluid.
    • During reassembly, the reversal of this step is slightly different. First, apply heat with the iron, then place the wire on the solder pin. Once the solder flows over the wire, pull the iron away and wait for the solder to solidify.
  7. Insignia Flex 7 Speaker Replacement: adım 7, 1 resimden 1.
    • Repeat the previous step to separate the speaker's black wire from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 219
