Ana içeriğe geç
Insignia Flex 8 NS-15AT08 Battery Replacement
Neye ihtiyacın var
  1. Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: adım 1, 2 resimden 1. Insignia Flex 8 NS-15AT08 Battery Replacement, Back Casing: adım 1, 2 resimden 2.
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Battery Replacement: adım 2, 2 resimden 1. Insignia Flex 8 NS-15AT08 Battery Replacement: adım 2, 2 resimden 2.
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: adım 3, 2 resimden 1. Insignia Flex 8 NS-15AT08 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Wedge a plastic opening tool in between the male, black module and female, white module to disconnect the wires module from the circuit board.
  4. Insignia Flex 8 NS-15AT08 Battery Replacement: adım 4, 3 resimden 1. Insignia Flex 8 NS-15AT08 Battery Replacement: adım 4, 3 resimden 2. Insignia Flex 8 NS-15AT08 Battery Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to pry the battery from the circuit board by wedging it around the perimeter of the battery.
  5. Insignia Flex 8 NS-15AT08 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the circuit board by lifting it with the spudger or finger.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jeremy Anaya
316 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-7, Williams Fall 2015 Baylor, Team 6-7, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,918
