Ana içeriğe geç
Insignia Flex 8 NS-15AT08 Internal Speakers Replacement
Neye ihtiyacın var
  1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement, Back Casing: adım 1, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement, Back Casing: adım 1, 2 resimden 2.
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 2, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 2, 2 resimden 2.
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement, Screen: adım 3, 1 resimden 1.
    • Use a plastic opening tool to flip up the black strip that is holding the orange camera ribbon near the module on the circuit board labeled "front camera" in white print.
    • Repeat this action on the orange camera ribbon near the module on the circuit board labeled "back camera" in white print.
  4. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 4, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to gently pull on both orange camera ribbons in the opposite direction in which they are connected until they disconnect from the modules on the circuit board.
  5. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 5, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 5, 2 resimden 2.
    • Peel the grey tape off of the device in order to separate the cameras and their respective ribbons from the rest of the device.
    • Do not use excessive force while removing the tape to prevent tears in the ribbons.
  6. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 6, 1 resimden 1.
    • Unscrew fifteen (15) 4mm Phillips #00 screws.
  7. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 7, 3 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 7, 3 resimden 2. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 7, 3 resimden 3.
    • Wedge a plastic opening tool between the black clip and white module on the large, orange display ribbon in the middle of the circuit board.
    • Pull the clip toward you with the plastic opening tool in order to completely disconnect the display ribbon.
    • The black clip holding this ribbon can fly out if enough force is used. Be careful not to lose that black clip.
  8. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 8, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to flip up the black strip on the white module which is holding the connection between the other display ribbon and the circuit board.
    • Once the black strip has been flipped up, the connection between the module and the ribbon has been unlocked. Use the spudger to pull the ribbon towards you in order to completely disconnect it from the circuit board.
  9. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 9, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 9, 2 resimden 2.
    • Pry out the antenna board with a plastic opening tool which is located right above the black internal speakers.
    • The antenna board is glued to the device, so some force might be needed.
  10. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 10, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 10, 2 resimden 2.
    • Lift the circuit board from the screen underneath and set it aside.
  11. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 11, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 11, 2 resimden 2.
    • Use a plastic opening tool to pry the LCD display away from the screen.
    • Make sure the display ribbons are not tucked underneath the LCD display when reassembling the screen and LCD display (as shown in the first image of this step).
  12. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement, Internal Speakers: adım 12, 1 resimden 1.
    • Turn the circuit board upside down so that the speakers are closest to you.
  13. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 13, 3 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 13, 3 resimden 2. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 13, 3 resimden 3.
    • Wedge a plastic opening tool between the black and white modules on the circuit board to disconnect the wires of the speakers.
  14. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 14, 2 resimden 1. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 14, 2 resimden 2.
    • On the back side of the circuit board, use a plastic opening tool to pry open the plastic speaker housing.
    • Use a metal opening tool for additional prying power, if needed. Metal opening tools should be used as a last resort, as they may cause further damage to the plastic speaker housing.
  15. Insignia Flex 8 NS-15AT08 Internal Speakers Replacement: adım 15, 1 resimden 1.
    • Desolder the speaker from its wires in the speaker housing.
    • Repeat this step to remove the other speaker.
    • You can pry the speaker out of the housing before desoldering the wire connections if you wish.
Sonuç
Jeremy Anaya
316 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 6-7, Williams Fall 2015 Baylor, Team 6-7, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G7
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 245
