Ana içeriğe geç
Insignia Flex 8 NS-P08A7100 Battery Replacement
Neye ihtiyacın var
  1. Insignia Flex 8 NS-P08A7100 Battery Replacement, Battery: adım 1, 2 resimden 1. Insignia Flex 8 NS-P08A7100 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Begin by using the opening tool to pry open the back cover. Continue around the edge until the back cover pops off.
  2. Insignia Flex 8 NS-P08A7100 Battery Replacement: adım 2, 2 resimden 1. Insignia Flex 8 NS-P08A7100 Battery Replacement: adım 2, 2 resimden 2.
    • Use the opening tool to flip the LCD flex circuit plug upwards. The flex circuit should now be loose. Remove flex circuit by pulling outwards.
  3. Insignia Flex 8 NS-P08A7100 Battery Replacement: adım 3, 2 resimden 1. Insignia Flex 8 NS-P08A7100 Battery Replacement: adım 3, 2 resimden 2.
    • Use the opening tool to remove the battery cable from the circuit board.
  4. Insignia Flex 8 NS-P08A7100 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the adhesive tape from the bottom of the battery.
  5. Insignia Flex 8 NS-P08A7100 Battery Replacement: adım 5, 1 resimden 1.
    • Remove plastic adhesive tape from the side of the battery.
  6. Insignia Flex 8 NS-P08A7100 Battery Replacement: adım 6, 2 resimden 1. Insignia Flex 8 NS-P08A7100 Battery Replacement: adım 6, 2 resimden 2.
    • Pry the battery from the back of the LCD screen using the opening tool. Due to the strong adhesive between the battery and screen, this may take some time.
Sonuç
Lavina Pillai
133 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Renguette Summer 2019 IUPUI, Team S1-G1, Renguette Summer 2019 üyesi
IUPUI-RENGUETTE-SU19S1G1
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 227
