Ana içeriğe geç
Insignia Flex 8 NS-P16AT08 Cameras Replacement
Neye ihtiyacın var
  1. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: adım 1, 3 resimden 1. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: adım 1, 3 resimden 2. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: adım 1, 3 resimden 3.
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Cameras Replacement: adım 2, 1 resimden 1.
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Cameras: adım 3, 1 resimden 1.
    • Gently peel all of the tape that is covering the cable connections going to and from the cameras. Set the tape aside for later reassembly.
  4. Insignia Flex 8 NS-P16AT08 Cameras Replacement: adım 4, 2 resimden 1. Insignia Flex 8 NS-P16AT08 Cameras Replacement: adım 4, 2 resimden 2.
    • Locate camera ribbon connector.
    • Using finger flip up black flap of camera ribbon connector.
  5. Insignia Flex 8 NS-P16AT08 Cameras Replacement: adım 5, 1 resimden 1.
    • Gently pull camera connector ribbon by hand until it separates from connector.
  6. Insignia Flex 8 NS-P16AT08 Cameras Replacement: adım 6, 1 resimden 1.
    • Using metal spudger tool, gently pry right speaker away from adhesive.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • Move right speaker to left side of device so you can freely access the camera ribbon.
  7. Insignia Flex 8 NS-P16AT08 Cameras Replacement: adım 7, 1 resimden 1.
    • Using metal spudger tool, gently pry the rear-facing camera from the adhesive.
  8. Insignia Flex 8 NS-P16AT08 Cameras Replacement: adım 8, 1 resimden 1.
    • Lift up connector ribbon that is attached to the cameras.
    • Slide cameras and connector ribbon out from underneath the speaker cords and battery.
  9. Insignia Flex 8 NS-P16AT08 Cameras Replacement: adım 9, 1 resimden 1.
    • Remove connector ribbon and cameras from device casing.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 227
