Ana içeriğe geç
Insignia Flex 8 NS-P16AT08 Screen Replacement
Neye ihtiyacın var
  1. Insignia Flex 8 NS-P16AT08 Screen Replacement, Back Casing: adım 1, 3 resimden 1. Insignia Flex 8 NS-P16AT08 Screen Replacement, Back Casing: adım 1, 3 resimden 2. Insignia Flex 8 NS-P16AT08 Screen Replacement, Back Casing: adım 1, 3 resimden 3.
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 2, 1 resimden 1.
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Screen Replacement, Screen: adım 3, 2 resimden 1. Insignia Flex 8 NS-P16AT08 Screen Replacement, Screen: adım 3, 2 resimden 2.
    • Pull gently on the cable that connects the microphone to the motherboard.
    • The microphone will stay attached to device and separated from motherboard.
  4. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 4, 2 resimden 1. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 4, 2 resimden 2.
    • Flip up the black flap of the connector ribbon that connects the screen to the motherboard.
    • Connector ribbon will stay attached to the device and separted from the motherboard.
    • If the black flap of connector will not lift by using your finger, then use the nylon spudger.
  5. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 5, 1 resimden 1.
    • Gently pull the connector ribbon by hand from the connector until it separates from connector.
  6. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 6, 2 resimden 1. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 6, 2 resimden 2.
    • Flip up the black flap of the connector ribbon that connects the buttons to the motherboard.
    • The connector ribbon will stay attached to the device and separted from the motherboard.
    • If the black flap of the connector will not lift by using your finger, then use the nylon spudger.
  7. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 7, 1 resimden 1.
    • Gently pull the connector ribbon by hand from the connector until it separates from the connector.
  8. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 8, 2 resimden 1. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 8, 2 resimden 2.
    • Gently pry the cameras from device using metal spudger tool.
    • Always try using a plastic opening tool or nylon spudger first. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • The cameras and connector ribbon will stay attached to motherboard.
  9. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 9, 1 resimden 1.
    • Remove the tape that is covering the screen motherboard connector ribbon.
    • The screen connection will now be exposed.
  10. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 10, 2 resimden 1. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 10, 2 resimden 2.
    • Flip up the black flap of the connector that connects the screen to the motherboard.
    • The connector ribbon will remain attached to the motherboard and separated from the screen.
  11. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 11, 2 resimden 1. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 11, 2 resimden 2.
    • Using a PH00 screwdriver, remove the (7) seven silver screws that connect the metal plate to the device.
    • Using a PH00 screwdriver, remove the (3) three black screws that connect the motherboard to the device.
  12. Insignia Flex 8 NS-P16AT08 Screen Replacement: adım 12, 1 resimden 1.
    • Gently lift the metal plate that is attached to the motherboard and battery and set aside.
    • Do not force the metal plate to separate from the screen!
    • If the metal plate does not separate from device freely, then you have not disconnected a connector ribbon or you have not removed all the screws. Repeat step 10.
    • Screen will now be exposed.
Sonuç
Bir Yorum
Where to buy it the display?
krnes1979 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 860
