Ana içeriğe geç
Insignia Flex Elite 7.85 Motherboard Replacement
Neye ihtiyacın var
  1. Insignia Flex Elite 7.85 Motherboard  Replacement, Motherboard: adım 1, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement, Motherboard: adım 1, 2 resimden 2.
    • Make sure the device is turned off before taking it apart to avoid any injuries.
    • Use a plastic opening tool to remove the metal backing of the tablet.
    • Insert the plastic opening tool between the screen and metal backing. Use a prying motion to lift the front case from the metal panel.
    • Move the tool around the perimeter of the device until the screen separate.
    • The volume and power button will become free from device when the screen and metal backing are separated. These small pieces are easy to lose, be careful. They’re easy to put back into place when reassembling the tablet.
  2. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 2, 3 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 2, 3 resimden 2. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to free the orange connector ribbon by placing the tool on the connector.
    • Peal the connector ribbon and bend it backwards so it is not in the way.
  3. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 3, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 3, 2 resimden 2.
    • Peel back the three pieces of tape circled in the picture.
  4. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 4, 1 resimden 1.
    • Free the battery from the motherboard by prying slightly with the opening tool.
  5. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to remove the battery from the screen.
    • Place the tool between the battery and casing. Move the tool around the border of the battery until it is free.
    • Do not bend or puncture the battery or the battery will begin to leak.
    • This step is very crucial. Be careful and do not rush through it.
    • The glue on the back of the battery is difficult to free up.
  6. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 6, 3 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 6, 3 resimden 2. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 6, 3 resimden 3.
    • Take the battery out carefully from the tablet
    • Remove the four screws with a #000 Phillips screwdriver.
  7. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 7, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 7, 2 resimden 2.
    • Place the speakers on the side.
    • Locate both front and back cameras.
  8. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 8, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 8, 2 resimden 2.
    • There are two black ribbon connectors that connects the cameras to the mother board.
    • Use a plastic opening tool to pry slightly on the black ribbon connectors.
    • Bend them backwards slightly so they will not be in the way.
  9. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 9, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 9, 2 resimden 2.
    • Using a plastic opening tool, pry the cameras from their mount.
    • Pry around the perimeter of the cameras until they come free.
    • Be careful, make sure the plastic mount does not break.
  10. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 10, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 10, 2 resimden 2.
    • Once the cameras are free, now it is time to peel the grey tape away from the connector
    • Using plastic opening tools, carefully pry the connector from the motherboard.
  11. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 11, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 11, 2 resimden 2.
    • Using a plastic opening tool, pry the black wire connectors pointed to in the picture.
  12. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 12, 1 resimden 1.
    • carefully, using a plastic opening tool, take the screen sensor from its molding.
    • Be careful not to break the plastic molding.
  13. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 13, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 13, 2 resimden 2.
    • Using a 000 philips screw driver, take out the four screws holding in the motherboard
    • Carefully, using a plastic opening tool, pry up on the motherboard.
    • The Motherboard should pop right out.
  14. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 14, 2 resimden 1. Insignia Flex Elite 7.85 Motherboard  Replacement: adım 14, 2 resimden 2.
    • The motherboard should be free from the tablet.
    • Replace the motherboard with the new one.
Sonuç
Antonio Olivieri
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G2, Martin Spring 2017 UMass Dartmouth, Team S9-G2, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 186
