Ana içeriğe geç
Insignia Ice Maker NS-IMP26SS7 Fan Replacement
Neye ihtiyacın var
  1. Insignia Ice Maker NS-IMP26SS7 Fan Replacement, Fan: adım 1, 2 resimden 1. Insignia Ice Maker NS-IMP26SS7 Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Undo the 6 Screws found on the bottom edge holding the rear casing on.
  2. Insignia Ice Maker NS-IMP26SS7 Fan Replacement: adım 2, 1 resimden 1.
    • Pull the casing off.
  3. Insignia Ice Maker NS-IMP26SS7 Fan Replacement: adım 3, 2 resimden 1. Insignia Ice Maker NS-IMP26SS7 Fan Replacement: adım 3, 2 resimden 2.
    • Locate the fan on the side of the Ice maker and undo the 4 screws holding it in place.
  4. Insignia Ice Maker NS-IMP26SS7 Fan Replacement: adım 4, 2 resimden 1. Insignia Ice Maker NS-IMP26SS7 Fan Replacement: adım 4, 2 resimden 2.
    • Remove the cover from the circuit board by pressing against the lever to the side. A pry tool may be needed.
  5. Insignia Ice Maker NS-IMP26SS7 Fan Replacement: adım 5, 3 resimden 1. Insignia Ice Maker NS-IMP26SS7 Fan Replacement: adım 5, 3 resimden 2. Insignia Ice Maker NS-IMP26SS7 Fan Replacement: adım 5, 3 resimden 3.
    • Follow the fan's power cable and unplug.
    • You may have to cut a zip tie holding the cable in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Evan Taylor
616 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G3, Banghart Winter 2018 Cal Poly, Team S21-G3, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S21G3
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 43
Her zaman: 1,633
