Ana içeriğe geç
Insignia NS-15MS0832B Power Button Replacement
Neye ihtiyacın var
  1. Insignia NS-15MS0832B Power Button Replacement, Power Button: adım 1, 1 resimden 1.
    • The power button is located on the top side on the tablet, along side the charging port and MicroUSB port
  2. Insignia NS-15MS0832B Power Button Replacement: adım 2, 1 resimden 1.
    • Starting in the corner, carefully insert the plastic opening tool.
    • Work the plastic opening tool carefully around the entire device to pry it open.
  3. Insignia NS-15MS0832B Power Button Replacement: adım 3, 1 resimden 1.
    • Once the tablet is completely open, set aside the back half.
    • Carefully place the other half of the tablet screen-side down.
  4. Insignia NS-15MS0832B Power Button Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, gently grab the power button and pull it out from the tablet.
  5. Insignia NS-15MS0832B Power Button Replacement: adım 5, 1 resimden 1.
    • Once the faulty power button is removed, follow the directions in reverse order to reassemble the device.
Sonuç
Harrison Smith
329 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 1-1, Bennett Fall 2016 Texas Tech, Team 1-1, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S1G1
4 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
If the power button doesn’t physically click anymore, can you order a replacement? Is it even possible to solder on a new power button?
Thanks in advance…
Chris - Yanıt
Can you do this with the volume rocker? My Insignia tablet has a faulty rocker, and I need to fix it. (Note- the “+” part of the volume button sticks and jams the volume to 100 until I press “-”.)
Andy Joonseo Bae - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,017
