Giriş
Use this guide to replace the infrared sensor in your Insignia NS-24ER310NA17 television.
Neye ihtiyacın var
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to remove the four screws on the bottom of the base.
Remove the base from the frame.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
Remove all the pieces of tape to detach the wires from both sides.
You want to gently peel the tape off, without pulling on the wires.
Remove all strips of tape attached to the silver steel rectangular piece.
Unplug the ribbon cable from the port on the main board that corresponds with the IR sensor.
2 farklı kişi bu kılavuzu tamamladı.
