Ana içeriğe geç
Insignia NS-24ER310NA17 Infrared Sensor Replacement
Neye ihtiyacın var
  1. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Remove the base: adım 1, 3 resimden 1. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Remove the base: adım 1, 3 resimden 2. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Remove the base: adım 1, 3 resimden 3.
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 2, 3 resimden 1. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 2, 3 resimden 2. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 2, 3 resimden 3.
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Pry the TV open: adım 3, 1 resimden 1.
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: adım 4, 3 resimden 1. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: adım 4, 3 resimden 2. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Disconnect wires: adım 4, 3 resimden 3.
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 5, 1 resimden 1.
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Motherboard: adım 6, 1 resimden 1.
    • Remove all strips of tape attached to the silver steel rectangular piece.
  7. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 7, 1 resimden 1.
    • Pull the red wire out from under the black plastic clip.
  8. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 8, 2 resimden 1. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 8, 2 resimden 2.
    • Unscrew the four screws surrounding the steel rectangle with a Phillips 00 Screwdriver.
  9. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 9, 1 resimden 1.
    • Carefully lift the rectangular piece.
  10. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 10, 1 resimden 1.
    • The rectangular piece will still be attached to the motherboard beneath it with a strip of tape. Remove this strip of tape.
  11. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 11, 2 resimden 1. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 11, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two screws on both sides of the motherboard.
  12. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 12, 1 resimden 1.
    • Carefully lift the motherboard away from the television.
    • Keep in mind that the motherboard is still attached by several thin wires and should not be tugged.
  13. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 13, 3 resimden 1. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 13, 3 resimden 2. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 13, 3 resimden 3.
    • There are 5 wires attached to the motherboard. Remove the two thicker white wires to the right of the red wire.
  14. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 14, 3 resimden 1. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 14, 3 resimden 2. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 14, 3 resimden 3.
    • Remove the remaining three wires from the mainboard.
  15. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 15, 1 resimden 1.
    • Carefully remove the mainboard from the television.
    • You have now successfully removed the mainboard.
  16. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Infrared Sensor: adım 16, 2 resimden 1. Insignia NS-24ER310NA17 Infrared Sensor Replacement, Infrared Sensor: adım 16, 2 resimden 2.
    • Unscrew single screw holding IR sensor and remove sensor with ribbon cable.
    • Place the new sensor where the old one was and replace the screw.
  17. Insignia NS-24ER310NA17 Infrared Sensor Replacement: adım 17, 1 resimden 1.
    • Plug the new sensor's cable into the motherboard. Make sure to plug it into the correct location.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joelle Hylton
260 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G2, Banghart Winter 2018 Cal Poly, Team S16-G2, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S16G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 50
Her zaman: 4,000
