Ana içeriğe geç
Insignia NS-24ER310NA17 Speaker Replacement
Neye ihtiyacın var
  1. Insignia NS-24ER310NA17 Speaker Replacement, Remove the base: adım 1, 3 resimden 1. Insignia NS-24ER310NA17 Speaker Replacement, Remove the base: adım 1, 3 resimden 2. Insignia NS-24ER310NA17 Speaker Replacement, Remove the base: adım 1, 3 resimden 3.
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Speaker Replacement: adım 2, 3 resimden 1. Insignia NS-24ER310NA17 Speaker Replacement: adım 2, 3 resimden 2. Insignia NS-24ER310NA17 Speaker Replacement: adım 2, 3 resimden 3.
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Speaker Replacement, Pry the TV open: adım 3, 1 resimden 1.
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Speaker Replacement, Disconnect wires: adım 4, 3 resimden 1. Insignia NS-24ER310NA17 Speaker Replacement, Disconnect wires: adım 4, 3 resimden 2. Insignia NS-24ER310NA17 Speaker Replacement, Disconnect wires: adım 4, 3 resimden 3.
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Speaker Replacement: adım 5, 1 resimden 1.
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia NS-24ER310NA17 Speaker Replacement, Speaker: adım 6, 2 resimden 1. Insignia NS-24ER310NA17 Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Unplug the red (right speaker) cord from the motherboard.
    • Unplug the white (left speaker) cord from the motherboard.
  7. Insignia NS-24ER310NA17 Speaker Replacement: adım 7, 1 resimden 1.
    • Start by locating speaker in bottom of back panel.
  8. Insignia NS-24ER310NA17 Speaker Replacement: adım 8, 1 resimden 1.
    • Remove screws on both sides holding the speaker in place.
  9. Insignia NS-24ER310NA17 Speaker Replacement: adım 9, 1 resimden 1.
    • Pull the speaker out of its casing, and repeat for the process for the other speaker.
Sonuç
Hannah Berenjfoorosh
533 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G2, Banghart Winter 2018 Cal Poly, Team S16-G2, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S16G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 975
