Ana içeriğe geç
Insignia NS-B2110 Battery Replacement
Neye ihtiyacın var
  1. Insignia NS-B2110 Battery Replacement, Battery: adım 1, 2 resimden 1. Insignia NS-B2110 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Battery Replacement: adım 2, 2 resimden 1. Insignia NS-B2110 Battery Replacement: adım 2, 2 resimden 2.
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Sonuç
Daniel Hodges
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G31
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 368
