Ana içeriğe geç
Insignia NS-B2110 Button Replacement
Neye ihtiyacın var
  1. Insignia NS-B2110 Button Replacement, Battery: adım 1, 2 resimden 1. Insignia NS-B2110 Button Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Button Replacement: adım 2, 2 resimden 1. Insignia NS-B2110 Button Replacement: adım 2, 2 resimden 2.
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Insignia NS-B2110 Button Replacement, Bottom Panel: adım 3, 1 resimden 1.
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Insignia NS-B2110 Button Replacement: adım 4, 2 resimden 1. Insignia NS-B2110 Button Replacement: adım 4, 2 resimden 2.
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Insignia NS-B2110 Button Replacement: adım 5, 3 resimden 1. Insignia NS-B2110 Button Replacement: adım 5, 3 resimden 2. Insignia NS-B2110 Button Replacement: adım 5, 3 resimden 3.
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  6. Insignia NS-B2110 Button Replacement, Internal Components: adım 6, 2 resimden 1. Insignia NS-B2110 Button Replacement, Internal Components: adım 6, 2 resimden 2.
    • With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board.
    • More wires! Handle the circuit board carefully and take caution not to stretch the red and white wires connected the board to the other components.
    • Remove the green quarter circle circuit board and place to the side.
  7. Insignia NS-B2110 Button Replacement: adım 7, 1 resimden 1.
    • On the brown side of the quarter circle circuit board, remove the two white ribbon cables with pink stripes attached to a plastic connector. To do this, pinch the tabs with your hands while pulling outward on the connector.
  8. Insignia NS-B2110 Button Replacement: adım 8, 1 resimden 1.
    • With a Phillips #2 screwdriver, remove four 6mm screws from the rectangular circuit board.
  9. Insignia NS-B2110 Button Replacement: adım 9, 1 resimden 1.
    • Remove the two white ribbon cables attached to white plastic connectors from the circuit board by pinching the tabs with your hands and pulling outward on the connector.
  10. Insignia NS-B2110 Button Replacement: adım 10, 1 resimden 1.
    • Red and white wires are attached to this board as well. Once again, be careful not to stretch these.
    • Remove the rectangular circuit board and place it to the side.
  11. Insignia NS-B2110 Button Replacement: adım 11, 1 resimden 1.
    • With a Phillips #2 screwdriver, remove two 5mm screws from the black plastic frame which previously held up the rectangular circuit board.
    • Remove the black plastic frame.
  12. Insignia NS-B2110 Button Replacement: adım 12, 2 resimden 1. Insignia NS-B2110 Button Replacement: adım 12, 2 resimden 2.
    • With a Phillips #1 screwdriver, remove four 3mm screws from the silver metal circuit board.
    • This board has two white ribbons attached to it. Once again, be careful not to stretch these.
    • Remove and place the metal circuit board to the side.
  13. Insignia NS-B2110 Button Replacement: adım 13, 1 resimden 1.
    • With a Phillips #2 screwdriver, remove the two 3mm screws from the black plastic tuner frame.
  14. Insignia NS-B2110 Button Replacement, Buttons: adım 14, 2 resimden 1. Insignia NS-B2110 Button Replacement, Buttons: adım 14, 2 resimden 2.
    • The tuner is fragile and can snap easily. Handle it with care.
    • Remove the black plastic tuner assembly piece using the blue plastic opening tool.
  15. Insignia NS-B2110 Button Replacement: adım 15, 2 resimden 1. Insignia NS-B2110 Button Replacement: adım 15, 2 resimden 2.
    • Turn the device so the CD tray faces up.
    • Use the blue plastic opening tool to separate the front half (containing the speakers and display) and the back half (containing the antenna).
    • When separating the device, keep in mind there are still wires attaches to the front half. Be careful not to damage these.
    • Pull the two plastic pieces apart. This will require a mild amount of force.
  16. Insignia NS-B2110 Button Replacement: adım 16, 2 resimden 1. Insignia NS-B2110 Button Replacement: adım 16, 2 resimden 2.
    • Remove the six 5mm #2 Phillips head screws from the circuit board.
    • Remove the circuit board. This may require you to wiggle the board a little to get it free.
  17. Insignia NS-B2110 Button Replacement: adım 17, 2 resimden 1. Insignia NS-B2110 Button Replacement: adım 17, 2 resimden 2.
    • Remove the solder from the back of the button. There are 4 points of solder for every button.
    • Remove the button from the circuit board.
Sonuç
To reassemble your device, follow these instructions in reverse order. Solder the wires back on where they have been soldered off.
Samuel Randall
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G31
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 328
