Giriş
Follow this guide to replace your LED display so you can navigate through your tunes easier. The wires get a little messy, so be sure you have a clean area to work in. This guide requires soldering. If you don't know how to solder, a simple step-by-step guide can be found here.
Neye ihtiyacın var
Flip the stereo so the CD opening is face down.
With two fingers, pinch the tabs and lift up to open the battery protection cover.
With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board.
Remove the green quarter circle circuit board and place to the side.
Using a Phillips #1 Screwdriver, remove the six 5mm screws from the circuit board
Remove the circuit board. This may require you to wiggle to board a little bit to get it free.
