Ana içeriğe geç
Insignia NS-B2110 Transformer Replacement
Neye ihtiyacın var
  1. Insignia NS-B2110 Transformer Replacement, Battery: adım 1, 2 resimden 1. Insignia NS-B2110 Transformer Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Transformer Replacement: adım 2, 2 resimden 1. Insignia NS-B2110 Transformer Replacement: adım 2, 2 resimden 2.
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Insignia NS-B2110 Transformer Replacement, Bottom Panel: adım 3, 1 resimden 1.
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Insignia NS-B2110 Transformer Replacement: adım 4, 2 resimden 1. Insignia NS-B2110 Transformer Replacement: adım 4, 2 resimden 2.
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Insignia NS-B2110 Transformer Replacement: adım 5, 3 resimden 1. Insignia NS-B2110 Transformer Replacement: adım 5, 3 resimden 2. Insignia NS-B2110 Transformer Replacement: adım 5, 3 resimden 3.
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  6. Insignia NS-B2110 Transformer Replacement, Transformer: adım 6, 2 resimden 1. Insignia NS-B2110 Transformer Replacement, Transformer: adım 6, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove two 4mm screws from the transformer box.
    • Remove the transformer and set it to the side.
  7. Insignia NS-B2110 Transformer Replacement: adım 7, 1 resimden 1.
    • Remove the solder connecting the two yellow wires to the green quarter-circle board.
  8. Insignia NS-B2110 Transformer Replacement: adım 8, 3 resimden 1. Insignia NS-B2110 Transformer Replacement: adım 8, 3 resimden 2. Insignia NS-B2110 Transformer Replacement: adım 8, 3 resimden 3.
    • There will be a strip of electrical tape securing the converter. Use scissors to carefully remove this tape.
    • Use a Phillips #2 screwdriver to remove two 4mm screws from the converter.
    • Remove the converter. There will be a plastic casing that slides off; set this aside.
  9. Insignia NS-B2110 Transformer Replacement: adım 9, 1 resimden 1.
    • Remover the solder from the red and yellow wires on the converter.
Sonuç
Jacob Phillips
313 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G31
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 301
