Ana içeriğe geç
Insignia NS-B4111 Antenna Replacement
Neye ihtiyacın var
  1. Insignia NS-B4111 Antenna Replacement, Battery: adım 1, 2 resimden 1. Insignia NS-B4111 Antenna Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug and remove the power cord. Turn the boombox upside down.
    • Grip the sides of the case and use your thumbs to pop open the battery cover.
  2. Insignia NS-B4111 Antenna Replacement: adım 2, 2 resimden 1. Insignia NS-B4111 Antenna Replacement: adım 2, 2 resimden 2.
    • Pry out the batteries with your fingers.
  3. Insignia NS-B4111 Antenna Replacement, External Antenna: adım 3, 1 resimden 1.
    • Set the boombox upright. Remove the 4mm screw and the two 6mm washers with the Phillips PH1 screwdriver.
    • Remove the external antenna.
  4. Insignia NS-B4111 Antenna Replacement, Casing: adım 4, 1 resimden 1.
    • Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
    • Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
  5. Insignia NS-B4111 Antenna Replacement: adım 5, 2 resimden 1. Insignia NS-B4111 Antenna Replacement: adım 5, 2 resimden 2.
    • Gently remove the bottom half of the casing from the top half of the casing.
    • The antenna base is connected to the motherboard by a red wire. This wire will prevent the two halves from separating completely.
  6. Insignia NS-B4111 Antenna Replacement, Antenna Base: adım 6, 2 resimden 1. Insignia NS-B4111 Antenna Replacement, Antenna Base: adım 6, 2 resimden 2.
    • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
    • This red wire will now be loose and you can move it out of the antenna base slot.
Sonuç
Kristin Yoshioka
984 İtibar
9 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-5, Oliver Fall 2016 UC Davis, Team 1-5, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S1G5
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 18
Her zaman: 770
