Ana içeriğe geç
Insignia NS-BCDCAS1 CD Laser Lens Replacement
Neye ihtiyacın var
  1. Insignia NS-BCDCAS1 CD Laser Lens Replacement, Outer Panels: adım 1, 2 resimden 1. Insignia NS-BCDCAS1 CD Laser Lens Replacement, Outer Panels: adım 1, 2 resimden 2.
    • Turn the boombox around to see the back, and then flip it upside down.
    • Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
    • Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
  2. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 2, 1 resimden 1.
    • Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
  3. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 3, 2 resimden 1. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 3, 2 resimden 2.
    • Remove the two 8mm screws using a 2.5mm flathead driver.
    • The front grey panel will loosen up once the final screw is removed.
  4. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 4, 1 resimden 1.
    • Turn the boombox on its back.
    • Release the front panel by pushing down on the latches holding the panels together.
    • There are four silver latches on the top side of the panel and one on the bottom.
    • Do not force the panel comletely off, there are cables attached inside.
  5. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 5, 2 resimden 1. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 5, 2 resimden 2.
    • Turn the boombox around to view the back and lift the handle up.
    • Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
    • Gently lift the black top but do not pull completely away.
  6. Insignia NS-BCDCAS1 CD Laser Lens Replacement, CD Laser Lens: adım 6, 1 resimden 1.
    • Unplug the red and black wires from the large yellow motherboard by pulling upwards.
  7. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 7, 1 resimden 1.
    • Unplug the thick, white and pink cord from underneath the black top by pulling downwards.
  8. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 8, 1 resimden 1.
    • Remove the black shiny strip from both ends of the white motherboard adaptor.
  9. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 9, 1 resimden 1.
    • Using a Phillips #0, remove the two 11mm screws attached to the green legs underneath the top panel.
  10. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 10, 1 resimden 1.
    • With a plastic opening tool, take off the red rings on the other two green legs.
    • The red rings fall off easily once loosened.
  11. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 11, 1 resimden 1.
    • Using a JIS 1, remove the 8mm screw on the grey, square plate.
  12. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 12, 3 resimden 1. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 12, 3 resimden 2. Insignia NS-BCDCAS1 CD Laser Lens Replacement: adım 12, 3 resimden 3.
    • Slide the silver bar out.
    • Everything will be loosened. Support it with your hand
    • The square cube with the tiny lense is loosened. Slide it down to take out of the nook.
    • Detach the black tape so the cube is completely by itself. Replace the cube with a new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Erin King
215 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-5, Bruce Fall 2016 CSU Fullerton, Team 2-5, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G5
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 969
