Ana içeriğe geç
Insignia NS-BCDCAS1 Cassette Door Latch Replacement
Neye ihtiyacın var
  1. Insignia NS-BCDCAS1 Cassette Door Latch Replacement, Outer Panels: adım 1, 2 resimden 1. Insignia NS-BCDCAS1 Cassette Door Latch Replacement, Outer Panels: adım 1, 2 resimden 2.
    • Turn the boombox around to see the back, and then flip it upside down.
    • Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
    • Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
  2. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 2, 1 resimden 1.
    • Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
  3. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 3, 2 resimden 1. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 3, 2 resimden 2.
    • Remove the two 8mm screws using a 2.5mm flathead driver.
    • The front grey panel will loosen up once the final screw is removed.
  4. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 4, 1 resimden 1.
    • Turn the boombox on its back.
    • Release the front panel by pushing down on the latches holding the panels together.
    • There are four silver latches on the top side of the panel and one on the bottom.
    • Do not force the panel comletely off, there are cables attached inside.
  5. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 5, 2 resimden 1. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 5, 2 resimden 2.
    • Turn the boombox around to view the back and lift the handle up.
    • Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
    • Gently lift the black top but do not pull completely away.
  6. Insignia NS-BCDCAS1 Cassette Door Latch Replacement, Cassette Door Latch: adım 6, 1 resimden 1.
    • Start by unplugging the red and black cable connected to the motherboard
  7. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 7, 1 resimden 1.
    • Unplug the red and pink wires connecting the top of the device to the motherboard
  8. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 8, 3 resimden 1. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 8, 3 resimden 2. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 8, 3 resimden 3.
    • Disconnect the black shiny tape connecting the motherboard to the front of the device
    • Also disconnect the pink and white wires connecting the cassette unit to the device.
  9. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 9, 1 resimden 1.
    • After disconnecting all the wires, the front panel is now free and easy to work on.
  10. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Satın Al
    • To remove the cassette unit, use a 2.5mm flathead on the 4 screws holding the unit together.
  11. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 11, 3 resimden 1. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 11, 3 resimden 2. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 11, 3 resimden 3.
    • While pressing the eject bottom, pull the cassette unit down and away from the front panel.
  12. Insignia NS-BCDCAS1 Cassette Door Latch Replacement: adım 12, 1 resimden 1.
    • The door latch is located on the bottom corner of the cassette unit.
Sonuç
diego geldres
148 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-5, Bruce Fall 2016 CSU Fullerton, Team 2-5, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S2G5
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 597
