Ana içeriğe geç
Insignia NS-CLIP02 30-Pin Connector Replacement
Neye ihtiyacın var
  1. Insignia NS-CLIP02 30-Pin Connector Replacement, 30-Pin Connector: adım 1, 1 resimden 1.
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 2, 1 resimden 1.
    • Begin by using the Metal Spudger to peel back the adhesive sticker and locate the screw beneath the sticker.
  3. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 3, 1 resimden 1.
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 4, 1 resimden 1.
    • Using the Plastic Spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 5, 1 resimden 1.
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 6, 1 resimden 1.
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 7, 1 resimden 1.
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 8, 1 resimden 1.
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 9, 1 resimden 1.
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 10, 1 resimden 1.
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 11, 1 resimden 1.
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 12, 1 resimden 1.
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 13, 1 resimden 1.
    • Remove the plug in front of the LCD screen plug.
  14. Insignia NS-CLIP02 30-Pin Connector Replacement: adım 14, 1 resimden 1.
    • Remove the LCD screen plug. Then, follow the previous instructions in reverse, replacing the old motherboard with the new one to fix the 30-Pin Connector.
Sonuç
Erik
405 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S9G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 206
