Ana içeriğe geç
Insignia NS-CLIP02 Speaker replacement and troubleshooting
Neye ihtiyacın var
  1. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Motherboard: adım 1, 1 resimden 1.
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 2, 2 resimden 1. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 2, 2 resimden 2.
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 3, 2 resimden 1. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 3, 2 resimden 2.
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 4, 1 resimden 1.
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 5, 1 resimden 1.
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 6, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 7, 1 resimden 1.
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 8, 3 resimden 1. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 8, 3 resimden 2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 8, 3 resimden 3.
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Speaker: adım 9, 1 resimden 1.
    • Remove the three screws located along the center of the base.
  10. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 10, 2 resimden 1. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 10, 2 resimden 2.
    • Remove the base from the display.
  11. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 11, 3 resimden 1. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 11, 3 resimden 2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 11, 3 resimden 3.
    • Using a metal spudger, remove the plastic face plate from the display.
  12. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 12, 1 resimden 1.
    • With a phillips screwdriver, remove the six screws shown pictured to the left.
  13. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 13, 2 resimden 1. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 13, 2 resimden 2.
    • Using the metal spudger, pry the speaker grilles from the display.
  14. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 14, 1 resimden 1.
    • Using the phillips screwdriver, remove the four screws pictured to the left.
  15. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 15, 1 resimden 1.
    • Separate the two pieces of the display as shown.
  16. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 16, 3 resimden 1. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 16, 3 resimden 2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: adım 16, 3 resimden 3.
    • You can see that there are several points where connections to the speaker are soldered.
    • If all connections are soldered then replacement may be necessary.
Sonuç
Aubrey
214 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S9G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 209
