Giriş
To replace many parts of the clock radio, the motherboard will need to be removed. This guide will lay out the necessary steps for that process.
Neye ihtiyacın var
Grip the white ribbon cable connector that attaches the lightning cable to the middle of the central circuit board located in the bottom of the clock. Pinch and pull straight up to detach the cable.
Use the narrow end of a plastic spudger to pull back the clip in the center of the board.
At the same time, pry the circuit board up by wedging another spudger into the top left-hand corner of the board and working it along the back, pushing the edge of the board away from the back of the clock.
Once the ports on the back of the circuit board are displaced and resting against the back of the clock, use a pair of tweezers to lift the circuit board up off of the bottom of the clock, continuing to feed the radio antenna through the side of the clock as the board lifts up.
