Ana içeriğe geç
Insignia NS-CLOPP2 Screen Replacement
Neye ihtiyacın var
    1. Insignia NS-CLOPP2 Screen Replacement, Screen: adım 1, 1 resimden 1.
      • Turn the clock over and remove the 1cm screw with a Philips head screwdriver, which is located below the faceplate, on the bottom of the clock.
      FixBot'a Sor
      Yorum Ekle
    2. Insignia NS-CLOPP2 Screen Replacement: adım 2, 1 resimden 1.
      • Begin to pry the front screen off gently with a Jimmy tool made by Ifixit.
      FixBot'a Sor
      Yorum Ekle
    3. Insignia NS-CLOPP2 Screen Replacement: adım 3, 1 resimden 1.
      • Once you are able to create a space in between the device and the front screen, use your hands to continue to pry off the screen. Make sure that all the mini latches surrounding the perimeter have been unlatched, allowing the screen to come off easily.
      FixBot'a Sor
      Yorum Ekle
    4. Insignia NS-CLOPP2 Screen Replacement: adım 4, 1 resimden 1.
      • Once you have undone the latches and pried off the first half of the screen, use your hand to pull off the rest of the screen.
      • To reassemble your device, follow these instructions in reverse order.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dilini De Silva
769 İtibar
5 adet Kılavuz yazıldı
Ekip
Marist, Team 1-1, Laflen Spring 2015 Marist, Team 1-1, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G1
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 574
