Ana içeriğe geç
Insignia NS-CSPBTHOL-R Speakers Replacement
Neye ihtiyacın var
  1. Insignia NS-CSPBTHOL-R Speakers Replacement, Speakers: adım 1, 1 resimden 1.
    • Insert the Spudger between the grated panel and the base of the speaker.
  2. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 2, 1 resimden 1.
    • Pull the grated panel off
  3. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 3, 1 resimden 1.
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  4. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 4, 1 resimden 1.
    • Insert the Spudger between the corners of base and the face of the speaker to open the device.
    • The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
  5. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 5, 1 resimden 1.
    • Remove one speaker at a time
  6. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 6, 1 resimden 1.
    • Grab the back piece of the speaker and gently pull upward.
  7. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 7, 1 resimden 1.
    • Remove speakers gently one at a time.
  8. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 8, 3 resimden 1. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 8, 3 resimden 2. Insignia NS-CSPBTHOL-R Speakers Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using blunted tip tweezers, squeeze and pull on the white plastic clip. This will separate the speaker's wires from the motherboard.
    • The wires are connected to the white plastic clip that is attached to the motherboard.
Sonuç
Lheessis Ruiz
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 12-6, Eyestone Spring 2017 USF Tampa, Team 12-6, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G6
3 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
This is a good app really could help some people like myself. Thank you
rrguerrero7330 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 20
Her zaman: 727
