Ana içeriğe geç
Insignia NS-DS9PDVD15 Screen Replacement
Neye ihtiyacın var
  1. Insignia NS-DS9PDVD15  Screen Replacement, Bottom Cover: adım 1, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Turn the power off. Slide the power button to OFF.
    FixBot'a Sor
  2. Insignia NS-DS9PDVD15  Screen Replacement: adım 2, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement: adım 2, 2 resimden 2.
    • Unplug AC adapter from car cigarette lighter.
    FixBot'a Sor
  3. Insignia NS-DS9PDVD15  Screen Replacement: adım 3, 1 resimden 1.
    • Make sure there is no DVD or CD in the disc tray
    FixBot'a Sor
  4. Insignia NS-DS9PDVD15  Screen Replacement: adım 4, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement: adım 4, 2 resimden 2.
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
    FixBot'a Sor
  5. Insignia NS-DS9PDVD15  Screen Replacement: adım 5, 3 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement: adım 5, 3 resimden 2. Insignia NS-DS9PDVD15  Screen Replacement: adım 5, 3 resimden 3.
    • Pry off back panel with prying tool, then remove by hand.
    FixBot'a Sor
  6. Insignia NS-DS9PDVD15  Screen Replacement, Disc Tray: adım 6, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement, Disc Tray: adım 6, 2 resimden 2.
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
    FixBot'a Sor
  7. Insignia NS-DS9PDVD15  Screen Replacement: adım 7, 1 resimden 1.
    • Slide the tray up and off of the hinge completely.
    FixBot'a Sor
  8. Insignia NS-DS9PDVD15  Screen Replacement, Screen: adım 8, 1 resimden 1.
    • After the bottom cover and disk tray have been removed, remove the back panel from the top half.
    • There are six, 9 mm screws on the bottom cover and 2 screws on the hinge. Remove them with the JIS #000 screwdriver.
    FixBot'a Sor
  9. Insignia NS-DS9PDVD15  Screen Replacement: adım 9, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement: adım 9, 2 resimden 2.
    • Once all the screws are removed, pry off the cover with the pry tool.
    • You'll see the PC board, back of the speakers, and the back of the screen.
    FixBot'a Sor
  10. Insignia NS-DS9PDVD15  Screen Replacement: adım 10, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement: adım 10, 2 resimden 2.
    • Remove the ribbon cable carefully with the pry tool.
    • First, push out the black portion.
    FixBot'a Sor
  11. Insignia NS-DS9PDVD15  Screen Replacement: adım 11, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement: adım 11, 2 resimden 2.
    • Next, push out the 'ribbon' with the pry tool.
    FixBot'a Sor
  12. Insignia NS-DS9PDVD15  Screen Replacement: adım 12, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement: adım 12, 2 resimden 2.
    • Unscrew the corners of screen with the JIS #000 screwdriver. There are four, 6 mm screws with washers.
    FixBot'a Sor
  13. Insignia NS-DS9PDVD15  Screen Replacement: adım 13, 2 resimden 1. Insignia NS-DS9PDVD15  Screen Replacement: adım 13, 2 resimden 2.
    • After the screws and washers are removed, you can lift the screen off with the pry tool.
    FixBot'a Sor
Sonuç
1Rehber Yorum
what is the model of the LCD Panel?
Justin Frost - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 908
