Ana içeriğe geç
Insignia NS-DS9PDVD15 Disc Reader Replacement
Neye ihtiyacın var
  1. Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: adım 1, 2 resimden 1. Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 2, 2 resimden 1. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 2, 2 resimden 2.
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 3, 1 resimden 1.
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 4, 2 resimden 1. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 4, 2 resimden 2.
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 5, 3 resimden 1. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 5, 3 resimden 2. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 5, 3 resimden 3.
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: adım 6, 2 resimden 1. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: adım 6, 2 resimden 2.
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 7, 1 resimden 1.
    • Slide the tray up and off of the hinge completely.
  8. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Reader: adım 8, 1 resimden 1.
    • Locate the disk reader, it will be right under the disk chamber.
  9. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 9, 1 resimden 1.
    • Pick it straight up, it should slide off the three pegs holding it in place, if not, wiggle each peg individually.
  10. Insignia NS-DS9PDVD15 Disc Reader Replacement: adım 10, 1 resimden 1.
    • Once you have it loose, unplug it from the PC Board. Then the disk reader can be removed.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 589
