Ana içeriğe geç
Insignia NS-F12R6-SS Motor Housing Replacing
Neye ihtiyacın var
  1. Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: adım 1, 2 resimden 1. Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: adım 1, 2 resimden 2.
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Motor Housing Replacing: adım 2, 1 resimden 1.
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Motor Housing Replacing: adım 3, 1 resimden 1.
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Motor Housing Replacing, Fan Blade: adım 4, 1 resimden 1.
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Motor Housing Replacing: adım 5, 1 resimden 1.
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Motor Housing Replacing, Back Cage: adım 6, 1 resimden 1.
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Motor Housing Replacing: adım 7, 1 resimden 1.
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: adım 8, 2 resimden 1. Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: adım 8, 2 resimden 2.
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Motor Housing Replacing: adım 9, 1 resimden 1.
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Motor Housing Replacing, Motor Housing: adım 10, 1 resimden 1.
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Motor Housing Replacing: adım 11, 1 resimden 1.
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Motor Housing Replacing: adım 12, 2 resimden 1. Insignia NS-F12R6-SS Motor Housing Replacing: adım 12, 2 resimden 2.
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Motor Housing Replacing: adım 13, 1 resimden 1.
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Motor Housing Replacing: adım 14, 2 resimden 1. Insignia NS-F12R6-SS Motor Housing Replacing: adım 14, 2 resimden 2.
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Motor Housing Replacing: adım 15, 1 resimden 1.
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Motor Housing Replacing: adım 16, 1 resimden 1.
    • Remove the small piece of paper hanging on the power button.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Hank
1.142 İtibar
8 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G1, Bruce Fall 2018 CSU Fullerton, Team S2-G1, Bruce Fall 2018 üyesi
CSUF-BRUCE-F18S2G1
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 1,658
