Ana içeriğe geç
Insignia NS-HD01A Battery Replacement
Neye ihtiyacın var
  1. Insignia NS-HD01A Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the rubber screw caps using the pointed tip of the Spudger.
  2. Insignia NS-HD01A Battery Replacement: adım 2, 1 resimden 1.
    • Remove the four 6.0 mm Phillips screws located below the rubber caps using the PH00 bit installed in the driver.
  3. Insignia NS-HD01A Battery Replacement: adım 3, 2 resimden 1. Insignia NS-HD01A Battery Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to pry open the back cover.
    • Slide the tool around the sides of the radio to gradually pry the back cover off. Do not remove the cover completely as there is still a cable connecting it to radio.
  4. Insignia NS-HD01A Battery Replacement: adım 4, 3 resimden 1. Insignia NS-HD01A Battery Replacement: adım 4, 3 resimden 2. Insignia NS-HD01A Battery Replacement: adım 4, 3 resimden 3.
    • Use the blunt tweezers to unplug the battery cable from the PCB board. Grab the battery cable plug from the sides.
  5. Insignia NS-HD01A Battery Replacement: adım 5, 2 resimden 1. Insignia NS-HD01A Battery Replacement: adım 5, 2 resimden 2.
    • Use the flat side of the Spudger to pry the battery out of the back cover.
    • Insert the replacement battery into the back cover.
    • Reassemble the radio, making sure to reconnect the battery cable.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joel Najmon
152 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Wilson Fall 2016 IUPUI, Team 2-2, Wilson Fall 2016 üyesi
IUPUI-WILSON-F16S2G2
5 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,020
