Ana içeriğe geç
Insignia NS-HTMC01-B Fan Replacement
Neye ihtiyacın var
  1. Insignia NS-HTMC01-B Fan Replacement, Fan: adım 1, 1 resimden 1.
    • Flip your device over so the back panel faces you. You should see a hole containing a screw in each corner of the device.
    • Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
  2. Insignia NS-HTMC01-B Fan Replacement: adım 2, 1 resimden 1.
    • Rotate the screwdriver counter-clockwise until screws are removed.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws impossible to remove.
    • Remove the back panel.
  3. Insignia NS-HTMC01-B Fan Replacement: adım 3, 1 resimden 1.
    • Unscrew the four 9 millimeter, sharp-point screws holding the fan in place.
  4. Insignia NS-HTMC01-B Fan Replacement: adım 4, 2 resimden 1. Insignia NS-HTMC01-B Fan Replacement: adım 4, 2 resimden 2.
    • Use tweezers to disconnect the red and black wires.
    • Remove the fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jack Casey
231 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
But what is the fan size?
William McGroarty - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 288
