Ana içeriğe geç
Insignia NS-HTMC01-B Power Button Replacement
Neye ihtiyacın var
  1. Insignia NS-HTMC01-B Power Button Replacement, Power Button: adım 1, 1 resimden 1.
    • Flip your device over so the bottom panel faces you. You should see a hole containing a screw in each corner of the device.
    • Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
  2. Insignia NS-HTMC01-B Power Button Replacement: adım 2, 1 resimden 1.
    • Find the power switch, located inside the heater on the bottom left corner.
  3. Insignia NS-HTMC01-B Power Button Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #1 screwdriver, unscrew the two 7 millimeter screws attaching the power switch to the power button.
  4. Insignia NS-HTMC01-B Power Button Replacement: adım 4, 2 resimden 1. Insignia NS-HTMC01-B Power Button Replacement: adım 4, 2 resimden 2.
    • Find the clips holding the power button in place.
    • Press down on the clips to remove the button.
Sonuç
Jack Casey
231 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 130
