Ana içeriğe geç
Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement
Neye ihtiyacın var
  1. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: adım 1, 3 resimden 1. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: adım 1, 3 resimden 2. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: adım 1, 3 resimden 3.
    • Flip the device over so the back panel faces up.
    • Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
    • You may want to use a flashlight during this step, as the screws are hard to see.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws nearly impossible to remove.
  2. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: adım 2, 1 resimden 1.
    • Take the screws out and set them aside.
    • Be sure to set them somewhere flat, so they don't roll away.
    • Gently pull the front panel and back panel apart to open the device.
  3. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: adım 3, 3 resimden 1. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: adım 3, 3 resimden 2. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: adım 3, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the 1.3mm screw on the black rectangle above the Tip-Over Safety Switch.
  4. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: adım 4, 3 resimden 1. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: adım 4, 3 resimden 2. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #2 screwdriver to remove the 0.9mm screw from the back panel of the Tip-Over Safety Switch.
    • Remove the back panel and the Tip-Over Safety Switch.
Sonuç
Rebecca Nunez
201 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 319
