Ana içeriğe geç
Insignia NS-SPBTBRICK Battery Replacement
Neye ihtiyacın var
  1. Insignia NS-SPBTBRICK Battery Replacement, Battery: adım 1, 2 resimden 1. Insignia NS-SPBTBRICK Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Run your hand around the device where the sleeve connects, lifting lightly up until the edges detach from the device case.
  2. Insignia NS-SPBTBRICK Battery Replacement: adım 2, 2 resimden 1. Insignia NS-SPBTBRICK Battery Replacement: adım 2, 2 resimden 2.
    • Turn the device around and gently push the speaker through until it separates from the sleeve.
  3. Insignia NS-SPBTBRICK Battery Replacement: adım 3, 2 resimden 1. Insignia NS-SPBTBRICK Battery Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the the ten 5.1mm screws that hold down the battery panel on the bottom of the speaker unit.
  4. Insignia NS-SPBTBRICK Battery Replacement: adım 4, 3 resimden 1. Insignia NS-SPBTBRICK Battery Replacement: adım 4, 3 resimden 2. Insignia NS-SPBTBRICK Battery Replacement: adım 4, 3 resimden 3.
    • Using your hands, pry the panel off of the top of the device to reveal the device circuit board and the battery attached to the inner side of the panel.
  5. Insignia NS-SPBTBRICK Battery Replacement: adım 5, 2 resimden 1. Insignia NS-SPBTBRICK Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully detach the battery wire from the circuit board and lift out the panel with the attached battery.
Sonuç
After detaching, you can replace with a new panel and battery, or detach the battery from the panel adhesive and replace the battery on the existing panel. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Austin Gratzer
127 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G6, Harley Spring 2018 IUPUI, Team S2-G6, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S2G6
3 Üyeler
2 adet Kılavuz yazıldı
Bir Yorum
Where can I get a new battery for my Speaker?
David Villa - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 1,013
